I was in the process of ordering the new BT Sport package (for free). During the order process, it says that if you have a powerpack (white plug), you have to change it to ethernet cables, and that the BT Vision box is automatically upgraded in 8 days time, and you have to watch all your existing recording as they'll be wiped by the upgrade process.
This means that the existing wireless system has to be changed to cable, and that all our existing recordings (music programmes from BBC4 that I'd want to keep long-term) are wiped out. As I have my BT Hub in an upstairs office, and the BT Vision box downstairs in the living room, it is not exactly a system I'd want to change over, if it meant wires across different floors and rooms (Wireless works so well for me in my current set-up).
Does anyone have any ideas on how to keep the existing wireless system and our existing recordings, and still get BT Sport package?
Someone Solved Your Question? ![]() Please let other members know by clicking on ’Mark as Accepted Solution’ | Helpful Post? If a post has been helpful, say thanks by clicking the ratings star. |
I don't 'need' an upgrade, as the system works perfectly well as it is. it seems that in order to get BT Sport, the system will automatically upgrade as part of the package purchase.
I did a speedtest as you suggested and the download speed is 46.65Mbps, and the uplaod speed is 16.12Mbps.
What I don't want to do is have to convert to cables when wireless works perfectly for our set-up. Losing the existing recordings is also a concern.
I wonder if it's possible just to get the new App and watch any programs on an iPad?
Thanks for your reply.
You can choose to ignore BT's advice to hard-wire the connection between the Home Hub and the BT Vision box. Provided that your wireless link is fast enough, it should still work. If it's not fast enough, then it won't work.
The old BT Vision software can't handle multicast streaming video. It's now obsolete, and will not be upgraded. Any new services are only offered on the new software platform.
