tb1234
Newbie
Message 1 of 2
picture freezing when watching bt sport on laptop
When watching matches in bt player on laptop picture freezes and then restarts and freezes again continuously.
No problem with watching on TV only on laptop. Have fibre over copper now. problem never happened before upgrading to fibre. No faults on equipt. BT sport trouble shooter does not seem to work.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: picture freezing when watching bt sport on laptop
@tb1234 can you connect your laptop to the hub via an ethernet cable and test it? This issue could be caused by connection speed problems.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
