keving6208
Message 1 of 2
youview via bt infinty hub
hi since bt said http://www.seenit.co.uk/bt-to-make-sports-channels-to-youview-retail-boxes/0527313/
bt sport via the bt hub via a ethernet cable to youview will this be the same for the bt infinity tv box?
its just i dont want a tv subscription
i just want bt sport 1 and 2 and espn on a youview box sky freesat box with viewing card or if thery do it via a bt infinity tv box
any help thanks kev.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: youview via bt infinty hub
Hi Kev,
Thanks for posting. You should find the answer in Seans sticky at the top of the board.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
