Do you mean
YouView box from BT WITHOUT infinity - BT Sport
Hi All,
I'm looking for people with a BT Youview Box, but without infinity to see if BTSport is working?
I know it says on the website that you need Infinity, but I can get 6mbs and can stream HD iplayer easily. So I'm wondering if they limit the YouView box, or require you to activate something before you can get access to the streams? Or Does bt sport require a higher bandwidth?
If I can ask for only the people in this situation to reply, or people with actual knowledge, not just re-hashed from the bt website, that would keep the topic on track.
I have looked on the forum for answers, but no one seems to have had done any real testing.
Thanks in advance,
Dawson
