Do you mean
BT sport on a smart TV
I have BT sport in my BT package.....I have a Smart tv (connected to wi-fi) and have two channels with BT sport, however when trying to access them all I get is channel scrambled.
How can I get the channels?
Re: BT sport on a smart TV
I think I have found all the answers I need for this.
Having just joined, I posted straight away but have now read a thread that is/has dealt with the problem....unless there has been an update on the problem since the last post..
this has been raised numerous times before and here is one thread http://community.bt.com/t5/BT-Sport/BT-Sport-via-LG-Smart-tv/m-p/1024626/highlight/true#M9751
if you search the board for 'smart tv' you will find numerous others which will help you
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
Recognised Expert
You won't be able to unscramble the channels on your Smart tv. You will need BTVision+ or Youview box. Details here:
http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=27270
Alternatively you can connect your pc or laptop to the tv and watch using the app.
