Do you mean
Newbie
Bt sport on samsung smart tv
Would I be able to buy the BT sky card for £10 and put it in the TV slot? Have tried downloading the app but no windows silverlight, then tried free view channel 57 as suggested, advised to retune TV and then advised to use channel 58 and 59, however these are encrypted so you cannot access them without the BT vision box. Any other ideas?!!!! It works great on the ipad
Guru
Re: Bt sport on samsung smart tv
No you can't use the CI slot in the TV. You need a Vision+ Box.
I also have a Samsung smart tv, bought this year, and the BT sport site tells me to download Silverlight. The tv then tells me I have no permission to download! Any ideas?
don't think the tv will allow you to download silverlight - my samsung doesn't
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
Distinguished Expert
[ Edited ]
Here is the list of supported devices:
The BT Sport App works on iPhone (3GS and above), iPad (iOS 5.1.1 and above) & selected Android devices with OS 4.1
Does your TV appear on that list?
To say thanks for a helpful answer, please click the white star
no but tv does have a browser which enables you to go to btsports homepage and do everything like a pc but because you can't download silverlight you can't play btsports  this is not an app required although an app for the samsung tv would be good
