Do you mean
0
Accepted Solution
bt sport hd channels
Hi guys, and gals,
Ok got me card can get sport 1 & 2
Registered before 1st August,  guy on the phone (friday) said he would activate the hd channels but cant see them in tv listings
Can see them in sport channels options setting, but go nowhere.
Have scanned a couple of times but no luck
Just thinking,  would it work if I took the plug out,  dropped it into a bucket of water,  and got the wife to replaced it into the socket, just a thought, tried everything else.
Well she doesn't like football.
Cheers, John
I
Moderator
0
Re: bt sport hd channels
Hi broondog,
Did you get this sorted? Let us know how you’re getting on.
Cheers
David
DavidM | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
Order tracker survey We would really appreciate it if you would take a few minutes to complete a survey about BT’s order tracker? You can access the survey from this link Order Tracker Survey
If you have a viewiing card that should mean BT Vision and no Infinity. This means no HD channels I'm afraid.
Sorry broondog, if you need a viewing card, that means you aint got infinity, that means the only HD you have is Huge Disappointment.
0
naw  mate, not sorted, just going to let the dust settle for a couple of years, then see what happens
0
such is life, ta anyway
