Message 1 of 14
0 Channels Available
Overnight I've lost every single channel!
TV Guide shows an error YVM305 which is no internet, but there is internet as IPlayer etc. are working fine.
Tried ethernet & wireless and 0 channels (free & subscribed)
I've spoken to BT this morning and everything has been rebooted, but no joy & I have an engineer coming out later in the week.
Does anyone have any suggestions of other things to try?
13 REPLIES 13
Message 2 of 14
Re: 0 Channels Available
@hkymre
https://support.youview.com/youview-box/error-messages/yvm305/
YVM305 is ‘No TV Channels’, not no internet. Has your TV aerial fallen down?
I suppose it might apply to ‘No IP TV Channels’ if you have a Pro box and are running it with no TV aerial, and the IP channels aren’t coming through for some reason, but you haven’t said that.
Which is it?
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Anonymous
Not applicable
Message 3 of 14
Hi I had similar thing this morning. "This channel not available". I was on BBC1 I switched off the box with remote and back on. Channel then worked perfectly, I have Pro box in IPTV mode.  It's not the first time it's happened.
Message 4 of 14
Sorry, it’s ipTV
Message 5 of 14
@hkymre  Are you able to open  the EETV player  on the box normally ?
Message 6 of 14
I can’t see a eetv player on the box
IPlayer, c4 apps are working fine
Recordings can’t be watched as the channel is no longer available
Message 7 of 14
Just a guess, is your Pro box connected to your hub via mini-converters or other powerline adapters by any chance?
If so, power them both down, wait at least 1 minute and then power them both back up again
Message 8 of 14
No, it’s Cat5e into a netgear switch.
But it’s not working on just WiFi either
Message 9 of 14
Have you tried running a network diagnostic (connection test) from the settings menu on the pro box
Message 10 of 14
I have had a similar problem twice now caused when a software update does not complete.
Try going to the software update in settings and forcing a check on new software. You'll probably get a message that the software is up to date. It is but it's incomplete.
I then had to do a soft reboot with no loss of recordings by the button press on the box method, NOT the on screen method.
