Message 1 of 2
2023 software update
Just completed a (recommended) 2023 update and all my recordings have been deleted and I have to reconfigure all apps. What’s going on?
1 REPLY 1
Message 2 of 2
Re: 2023 software update
Thankfully not a normal result of software updates. Unfortunately if the box has done the equivalent of a full factory reset  the settings and recordings won’t be recoverable.
Which box are you using and what software version are you now at ?
You can get that information  by doing  HELP an INFO on your remote   ( first couple of lines give the info)  or from the SETTINGS section of the box.
Also how were you prompted for the update .
