Message 1 of 4
4g Minihub unable to connect to my BTYouview Box
Am awaiting a replacement Home Hub that was rendered inoperable due to a lightning strike.
My Halo 4g Minihub was switched on by BT and giving me WiFi to my various "bits"
I want to watch the Apps, in particular "Yesterday"  on my BT You view Box, as this does not come with my Panasonic TV.
How do I activate my 4g Minihub WiFi to provide my BT Youview Box the  Apps contained therein ??
Is there an alternative work around untill I get it the arrival of a New Home Hub ??
Thanks in antisipation
3 REPLIES 3
Message 2 of 4
Re: 4g Minihub unable to connect to my BTYouview Box
PS. Ignore the title Aspiring Expert under my name as it is defo NOT the case !!!
If some knows how to remove it it would be appreciated ?
Message 3 of 4
Unless you have a Pro Box, you can't as it's only the Pro Box that has WiFi
Message 4 of 4
ok thanks for that info
