Message 1 of 2
Alexa on 4k box
Is alexa voice control still supported on the 4k box?
1 REPLY 1
Message 2 of 2
Re: Alexa on 4k box
Unfortunately not. The official response at the moment is "We're in conversation with Amazon on rolling out the Alexa capability to more BT TV boxes in the future".
Edit: if you mean the old 4K box (DTR-T4000), then yes - it's there.  If you mean the current BT TV Box Pro, then the above applies.
