Message 1 of 13
All freeview channels have gone
Hi, 2 days ago all channels up to 324 (Sky) disappeared. What I've tried. . .
Returned my box = 'no signal' so no channels
Returned Freeview on TV = same message
Bought aerial booster and new cable = made no difference.
Plugged aerial in TV (bypassing box) = same result
Checked for outside interference =Crystal Palace no problems and no local problems reported.
We're in a flat and nobody else in the block has aerial problems.
Any ideas please? Thanks in advance, I'm at the hair-pulling stage!
12 REPLIES 12
Message 2 of 13
Re: All freeview channels have gone
Just because no one else in the block has this problem doesn’t mean it’s not the aerial itself, there may be some sort of RF distribution network in the block and unfortunately your part of it seems to have developed a fault…you have effectively proved it’s not your equipment because the TV and set top box are displaying  ‘no signal’ , a signal booster is no use if their is no signal in the first place.
If you are renting , the TV ‘network’ rather than your equipment may be part of the rent , so your landlord may be responsible…if it’s your flat or the landlord isn’t interested, then access to the common areas etc where the communal aerial and distribution equipment is sited would be needed but if new equipment that is part of the RF distribution network is needed how you would deal with that as its ’commercial’ type equipment, is unclear  …TBH , an indoor aerial or a ‘freely’ TV that uses the internet to access Freeview stations may be the solution, if your TV box is the correct type , then it may already have ‘IP Mode’ so you can get  the main missing channels back that way because it can get those channels via the internet .
Anonymous
Not applicable
Message 3 of 13
BT/EE don't use Freeview....
Message 4 of 13
BT/EE don't use Freeview..….?
Anonymous
Not applicable
Message 5 of 13
Freeview Freely Youview....guess which one BT/EE use...give you a clue,  doesn't start with F
Message 6 of 13
@Anonymous Freeview is the United Kingdom's sole digital terrestrial television platform. It is operated by Everyone TV and DTV Services Ltd, a joint venture between the BBC, ITV, Channel 4, Channel 5 and Sky. It was launched on 30 October 2002,[1] taking over the licence from ITV Digital which collapsed that year.
Youview is the software that BT/EE use for their hybrid system which allows subscription TV delivery alongside the Freeview terrestrial network.
Freely is a new platform that delivers TV via IP on a non subscription basis.
Message 7 of 13
Thank you, I've emailed landlord re roof aerial ... I'll look into your other suggestion (not very technical!)
Message 8 of 13
OK, I meant the usual BBC, itv, etc
Message 9 of 13
OK, so I'm looking at Freely and YouView?
Message 10 of 13
I just add one thing to what @iniltous has said, and that's to check the antenna patch cable from the wall to the TV/box.  I've seen them where there's been a hidden break, and also one that was killed by a pet ferret! Oh, and TV boosters should not be used downstream from the TV distribution systems you commonly find in flats/apartments!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
