Message 1 of 18
Amazon Prime App on TV
Amazon Prime cannot be watched through the TV/BT box. All other apps work fine including BTTV, Netflix Apple and Disney etc and BT Fubre so no issue with wifi speed etc.  Amazon Prime app slow to load and operate then if try to watch video will either play for a minute or two before returning to main menu or is just sticking at the spinning wheel and then cutting out again.  Says software up to date. Any ideas?
17 REPLIES 17
Message 2 of 18
Re: Amazon Prime App on TV
@adrianbryan
Amazon Prime is at the outer limits of what early YouView boxes can handle.
Which model are we talking about here?
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 3 of 18
If theres an issue with Prime on YouView boxes, it's a bug that amazon will need to sort out via YouView.
There's no Disney plus app so presuming you meant Discovery plus.
Message 4 of 18
@Weerab1983  The OP said "Disney etc" not "Disney plus".
Message 5 of 18
There is no Disney on EE youview boxes, same thing
Message 6 of 18
Hi Sorry I am not sure what type of BT box it is. I've attached a couple of images if that help?  It is a seperate apple tv box with Disney Plus in it that is also plugged in to tv. Just mentioning that to emphasise that it and all other apps on BT box like Netflix work  instantly as you would expect. It is only Prime Video that has any issues.  IMG_20240923_103134.jpgIMG_20240923_103141.jpg
Many thanks
Message 7 of 18
@adrianbryan
That’s a DTR-T2100, the oldest and slowest BT YouView box, which will give the slowest and least satisfactory performance on the single most demanding app running on YouView boxes.
Can you run Amazon Prime from the Apple TV, like you do Disney?
Message 8 of 18
Several  of the apps currently  on that generation  of Youview box will be limited by the box own hardware and build so if the app runs acceptably  then great but if you experience  performance  drop-off or need to have the full range of features  for some of the apps you really are better off using the app on a different  device or platform. If you are a BT broadband  customer  with a current  EE TV subscription  then you can contact them  wrt a replacement  (later) model  box.  They should  be able to advise you of all of the options  both with your current EE TV term  and any offers for taking out a new contract which might be with either BT or EE broadband. Be prepared  for them promoting the new EE option but there should  be a range of options available.
Your existing  (pre 2019) box should  be yours to keep if you so wish.
Message 9 of 18
Thanks for your time. By coincidence I was onto EE to uograde my mobile and they have now done a package deal which basically means I am going to get a new TV box anyway - so hopefully problem solved.  Many thanks
Message 10 of 18
Keen to know if the new box plays the Amazon Prime movies now. Have the same problem and it’s driving me mad 😠. Thanks in advance
Tags (1)
