Message 11 of 12
Re: Amazon and ITV Hub and old Samsung TVs
@David_Hwrote:
Thanks @Les-Gibson that's useful to hear - whilst rebooting the hub is extreme, it's fair to say that the old "switch it off and on again" routine is a tried and tested solution for many IT related issues!
Doing that will give the device a chance to refresh, clear caches and reset process threads etc that consume memory and resources in normal use, so it's a useful check when all else fails.
Out of interest, when you experienced the issue, was the TV connected via Wi-Fi or a LAN port? depending on connectivity at the time, may point to a potential cause, but not one that may be applicable to Clive's issue. Something to look at though.
Cheers
David
Just thought I'd post an update. ITV Hub failed again last night and once again I restarted my SH2 and now it's working again
P.S. TV is connected on 5GHz channel 48
Message 12 of 12
Hi David. Have had a chance to investigate? I sent my details by private DM.
