Message 1 of 9
Apps on BT freeview box not working
Problem began yesterday on BBC - lots of buffering and other apps (ITV, 4 and My5) showing same problems. Some impossible to get onto. Have reacanned channels and checked for laters software updates.
When I try to update the apps it sends me to this site but does not give any error message to look up
8 REPLIES 8
Message 2 of 9
Re: Apps on BT freeview box not working
Have rebooted your box?
Message 3 of 9
Yes that was the first thing I did.
Message 4 of 9
Try a full reset through maintenance mode. You can do this without losing your recordings
Message 5 of 9
The Amazon Prime app was playing up yesterday evening on the BT box but I have the Amazon Prime app as a back up on the Amazon Firestick. So used that.
All seems to be working again.
Darren
Message 6 of 9
Im not a techie (in my 70s) but will get geeky nephew to try maintenance mode on tuesday when he visits. I can access the apps vis the AZ firestick but I would like to get them working on box again. This happened once before and I think we had to do a factory reset. However I have watched all my curent recordings so its not a tragedy if they have to go.
I think the last app update on May 5 may have been corrupted as that was when it began to go pearshaped.
Message 7 of 9
@biglouis
Many of the most helpful members here are in their 70's or at least over retirement age 🙂
Here's a link for doing the maintenance mode resets and talks about the various options. Options 2 and 4 save your recordings and should be tried in that order.
Message 8 of 9
@biglouis @TimCurtis
Agreed! Three cheers for us old f*rts!
Message 9 of 9
Thanks all, We will try these suggestions.
