Message 1 of 9
Apps on EE TV Box
Just started with BT/EE yesterday for TV & broadband - how can I remove or add apps to my TV box? There are a couple on there that I don't want the kids to see/use but can't find out how to remove or at the least hide them.
Thanks in advance.
Tags (2)
8 REPLIES 8
Message 2 of 9
Re: Apps on EE TV Box
@beleaguereddad
Is your account with BT or EE?
If you are an EE customer, you need to post on the EE forum https://community.ee.co.uk/
EE are a separate company within the BT Group.
Message 3 of 9
All a bit murky really - the router has BT on it, the box the kit came in has BT on it but the remote has an EE logo as the on/off button. As far as I'm aware, I'm a BT customer but who knows!
Message 4 of 9
@beleaguereddad
Did you setup a BT ID or an EE ID, when you placed your order?
https://id.ee.co.uk/login
Or https://my.bt.com/appsconsumeraccount/secure/dashboard.do
Message 5 of 9
BT
Message 6 of 9
@beleaguereddad
That is a bit odd if BT are trying to get new customers onto EE?
You are on the right forum, so hopefully one of the forum members can help, as I do not have a TV account.
Message 7 of 9
AFAIK there is no way to add it remove apps from BT or EETV.
Message 8 of 9
@beleaguereddad
Alas, you can’t remove or hide them 😢
But you should investigate Parental Controls on BT or EE, once you have clarified whose broadband you have.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 9 of 9
Thanks everyone for your input, much appreciated. Hiding the remote may be the order of the day.....
