Message 11 of 30
Re: BBC iplayer UHD content on BT TV Box Pro
@JulioP Prime shows available UHD content and it plays as such. It is just the iPlayer app that is the issue. It was ok a few weeks ago. I no longer have BT sport so I can't try the UHD channel there.
Message 12 of 30
Hi @zulu17 , I'm having the same issue, there is no option for play UHD test loop on the iPlayer app on my pro box, but there is on the TV iPlayer app. It must be an issue with the app, although that box says all apps are up to date.
Message 13 of 30
Hi,
I am getting the same issue with the iPlayer app on by pro box, The Football is advertised as HDR If you watch this through the iPlayer app, however when I go to watch this through the app on my BT box, I do not receive UHD or HDR on anything, However, when I watch iPlayer through the app locally installed on my TV, I can receive HDR and UHD no problem.
on a sidenote, I can receive BT sport through HDR no problem on the BT box.
thanks for any advice.
Message 14 of 30
They Euros coverage on BBC isn't UHD HDR, it's 1080p HDR and the HDR of choice for the BBC is HLG so your TV needs to support this format
Message 15 of 30
Hi @NigelB72
thanks for your reply,
I can watch it in hdr on my tv using the local bbc app installed no problem, so tv must support it however through the app on bt box no hdr I’m afraid.
Message 16 of 30
The Pro Box does support HLG but you probably need to tweak the settings
Message 17 of 30
Thanks @NigelB72
that’s good to know,
any idea what settings should be set to as quite limited options on it to tweak,
have tried changing the picture settings, currently on hdmi display UHD 50fps 10bit
Tried 8 bit with same results unfortunately,
I did notice i am unable to get uhd on anything on iplayer through BT but do on tv app guess that’s same reason for not getting hdr to.
Message 18 of 30
This issue rectified itself on my box some time ago, but I prefer to use the native apps on my TV as the picture quality is far superior.
Message 19 of 30
In my case the issue disappeared after playing with the settings for a bit and then returning to the main screen.
@Sonic1978 if you don't get any UHD content on any other channel via BT box, it could be the HDMI cable or HDMI port you are using on your TV, maybe try another port?
Message 20 of 30
Hi @JulioP
thanks for your reply, I do get UHD & HDR on other content through my BT pro box bt sport ultimate, prime etc,
so unfortunately, this seems to be only the BBC iPlayer app through the BT pro box.
