Message 1 of 7
BT Box Ethernet connection
Hello
i have BT box pro connected to smart hub via Ethernet. However it seems to disconnect from the internet quite regularly and therefore the apps and content will say ‘not available’ on the menus.
It’s an Ethernet direct connection so I would have expected a good connection. Note that when this happens all the other devices in my house carry on working so it can’t be the internet going down. Unplugged and plugging Ethernet cable seems to fix the errors
Any tips to keep a solid connection between Box and Hub?
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: BT Box Ethernet connection
Try another cable & a different port on the router.
If still no joy try giving the box a static IP address.
Message 3 of 7
If all other devices are OK then it points to a problem with the cable or pro box, try the advice already given and if that doesn't work then try the troubleshooting steps outlined at How do I reset my BT TV box? | BT Help
Message 4 of 7
Thanks all
Message 5 of 7
@FC12 I had the same issue and swapping the ethernet cable fixed it.
Message 6 of 7
Great thank you !
Message 7 of 7
Unfortunately this problem persisted for me. I changed cable, reset box etc.
BT sent me a new box with no fuss hopefully the sorts the issue.
