Message 1 of 2
BT Box Pro not showing TV Guide, Cannot set recordings
My BT TV Box Pro is showing nothing in the TV guide this morning, and as a result all scheduled recordings have disappeared and none can be scheduled. The football this morning is showing as "Failed to Record" and the scheduled recordings have all disappeared. Is something happening with the guide today or is it my box? I have already done a forced reset and it is just the same. Any info would be appreciated.
1 REPLY 1
Message 2 of 2
Re: BT Box Pro not showing TV Guide, Cannot set recordings
OK, I did the more involved reset using the reset button on the right of the box, then a software reset and it seems to be working now.
