Message 1 of 5
BT Box Pro poor picture quality
Hi all,
I have searched the forum without success for this specific issue.
when watching live tv or recordings the picture quality is poor.
if I switch to an alternative device ie - Xbox or fire stick the quality improves.
I think this proves the TV is ok, this has only happened since switching to pro box.
wishing I had the old brick back 🥹
happy to try any recommendations
4 REPLIES 4
Message 2 of 5
Re: BT Box Pro poor picture quality
Hi there, I recently went through this exact same issue. It is a common frustration with the Pro Box. Before you give up on it, here is a 4-step checklist that usually helps:
 Check the HD and 4K Add-on: Ensure the HD and 4K add-on (usually 6 pounds a month) is actually active in your account. Without it, the box defaults to Standard Definition for internet channels, which looks very poor on a 4K TV.
 The 1080p Trick: Many find the Pro Box is poor at upscaling. Go to Settings, Picture and Sound, HDMI Display and try changing it from UHD to 1080p. Often, a Sony or LG TV does a much better job of upscaling the signal than the box does.
 HDMI Enhanced Mode: Check your TV settings for the HDMI port the box is using. Look for a setting called Enhanced Format or HDMI UHD Color. If this is off, the colors can look washed out or milky.
 Internet Mode vs Aerial: If you are using the box without an aerial, the quality depends on your Wi-Fi. If the Wi-Fi dips, the box lowers the resolution. If you have an aerial, try using that instead for a more stable picture.
Hope this helps! Using the apps directly on your TV or a console like the Xbox or PS5 often gives a much better picture than the box itself.
Message 3 of 5
None of this worked unfortunately.
been online for over an hour with “support” useless
Message 4 of 5
Hi there @Spewy87
Thanks for posting on the community.
If this has not been resolved for you since you last posted, please give our TV tech guides a call on 0330 1234 150, they will get the TV box looked into and see what is needed to help resolve the issues with the picture quality.
Thanks 🙂
Leanne.
Message 5 of 5
Tried that, 1 hour on a call still no resolution 🤷🏻
I don’t have the patience for another hour.
