Message 1 of 4
BT DTR-T2100 Apps not working
  • I have done a factory reset from the settings menu and restarted several times but still none of the apps will work ? I have tried to update software from the menu but it doesn't update.  Help please.
3 REPLIES 3
Message 2 of 4
Re: BT DTR-T2100 Apps not working
Further to this I have started the box in maintenance mode and first tried the software reset to no avail.  Then did full factory reset and it still doesn't work.  Any further ideas on how to get the apps working much appreciated.
Message 3 of 4
FIXED I unfairly blamed the Humax box !! Once I'd reset the router the apps started working again.
Message 4 of 4
I'm having the same issue. When you say you 'reset' the router was that you pressing the Factory Reset button?
