Message 1 of 3
BT PRO BOX REMOTE PAIRING
I have just been sent a new Pro box to replace my old you view box which was having connection problems. I have an issue with the new remote which it is claimed will usually suffice for both the box and tv. The TV is a relatively new Sony.
I have used all the suggested restart, reset etc methods ( home 9, home 7 ) to no avail other than controlling on/off and volume. Is it actually   possible to get complete pairing ie change channels, use numberpad for TV etc  or am I wasting my time?
2 REPLIES 2
Message 2 of 3
Re: BT PRO BOX REMOTE PAIRING
I believe the remote only controls the volume and standby functions on the TV. It's been over a year since I had one, but I don't remember being able to do anything else with the remote on the TV itself.
Message 3 of 3
Ok, thank you. I did wonder. Its just that the guide seemed to suggest ' pairing' such that I would only need one remote.
I will stick with 2. In fact, as it still works with the new box, I shall stick with the old one which , I feel, has better functions.
