Message 1 of 4
BT Pro Box - using 'Info' button result in blank screen, apart from pgm name and channel id.
When I use the Info button on the BT Pro Box,  it  results in a blank screen, apart from pgm name and channel id. Any ideas?
3 REPLIES 3
Message 2 of 4
Re: BT Pro Box - using 'Info' button result in blank screen, apart from pgm name and channel id.
Miraculously, the fault has cleared itself! 🤷🏻‍♂️
Message 3 of 4
I suspect  that sort of issue may clear itself  by restarting the box .
Message 4 of 4
@zulu17  Yeah, that was what I was going to do, but when I switched on on this morning to do so, the fault had cleared.
Thanls for your reply. 👍
