My box has failed and I have been told that a new one will be despatched.
I have checked the online order system and it says delayed.
Have spoken to BT a couple of times, they cannot tell when, what the delay is and when it will be despatched.
The only suggestion they had was to cancel the order and re-order, which will delay it even more.
There does not seem to be any urgency for an existing customer.
Very unhappy customer
Solved! Go to Solution.
With the relaunch of BT TV last week, the TV Box Pro has now changed shape again. We have plenty of stock of the new box, so I'm not sure why your order is currently showing "Awaiting Stock". I've asked a colleague to take a look.
Thank you Darren,
Hopefully it will arrive sooner rather than later.
Its great to know that at least somebody knows whats going on.
Look forward to seeing the new shape box when it arrives
Fault found, and is now being fixed (a disconnect between old and new product codes).
The order should hopefully progress tomorrow morning - I'll check when I sign on.
Thank you Darren,
You are a star,
Thank you for getting to the bottom of the problem.
Looking forward to seeing the updated order tracking tomorrow.
Thank you again for your help
The TV Box Edge is included in the BT TV announcement: https://community.bt.com/t5/BT-TV/Simply-Brilliant-TV-is-here/m-p/2473026#M85357 .
This help article also has a photo of the fronts: https://www.bt.com/help/tv/learn-about-tv/bt-tv-boxes
I can confirm that your item has now been allocated, and should be collected by Evri today. It should be delivered by Saturday.
Thanks,
Have had a text and tracking info today as you said i would.
Much appreciated
