Message 1 of 2
BT TV Bok
My Bt Box with recording facility stopped operating. I had been having connection issues with internet, but got everything else working.
Rebooted the box but it seemed as if remote was not working. Connected an old BT box and remote worked perfectly. Reconnected latest box, showed up BT TV options, which then disappeared as normal. Tried to use remote, and then box buttons manually got no action.
As some point I got a message suggesting that I did not have package to access channels, but this was nonsense. Anyway, as it stands box does not respond by remote or manually.
Anyone had this happen? Also if it comes to the worst and i have to replace it, can you transfer recorded programs to a new box?
Terry Wyld
1 REPLY 1
Message 2 of 2
Re: BT TV Bok
@Terwyl
I can only reply to your last question to which the answer is NO for HD/4K recordings as they are linked to that one device but for SD recordings it is possible to extract them and view them separately but not transfer them though. It's a complicated process requiring the hard drive to be removed and mounted on a Unix computer etc.
