Message 1 of 3
BT TV Box Pro Channel Guide
I know you can use the yellow button to hide any channels you don't want to see, but is there a simple way to restrict the list automatically to only the channels you can receive - both via your aerial and via the internet on your BT contract?
At the moment, I am having to go through the list laboriously hiding the channels (particularly the internet ones) that I cannot view. And if one does a factory reset for any reason, I assume you have to start from scratch again!
2 REPLIES 2
Message 2 of 3
Re: BT TV Box Pro Channel Guide
Nope. As far as I'm aware, no pay tv platform allows this. Think of the EPG as extended advertising which lets you see what you could be missing out on.
Message 3 of 3
Thanks. I feared as much!
