Message 1 of 2
BT TV Box Pro--how to check remaining storage
Everybody was absolutely right--the issues I was having were to do with the TV subscriptions and Digital Voice handsets not being activated (and legacy phone wire still there). Fine now: only took two engineer visits and rather a lot of support calls to fix.
Next question: the Humax box had a tidy little gauge at the bottom showing how much storage is free/used. How would I get this? I intend to clear things once watched apart from a few I'd keep, but it'd be good just to keep an eye on it.
1 REPLY 1
Message 2 of 2
Re: BT TV Box Pro--how to check remaining storage
Hi @Wub  if you select +MYTV and press OK   from the home page under RECORDINGS & WATCHLIST  you will be on your Recordings page , the % FREE  space is shown at the bottom.
