Anonymous
Not applicable
Message 11 of 14
Re: BT TV PRO Box signal issues
@Midnight_Voicewrote:
"I see whoever is designing these tuners is still managing to keep them not sensitive enough and too sensitive at the same time, which is quite an achievement 😢"
They probably work fine on the test bench, where under lab conditions the signal levels can be carefully controlled!
Message 12 of 14
@Mark_lacey
The attenuator purely turns the SS down. If we are correct that yours is a good signal, but effectively too strong, the SQ should rise as you reduce the SS, and reach 100 before the SS drops below 90.
If this doesn’t happen, you have something different wrong with your signal. We’ve had a couple of reports lately about Box Pros being rather picky, but both in cases where there was something wrong with the signal, though TVs, and even earlier YouView boxes, weren’t finding anything to complain about.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 13 of 14
I received the attenuator in the post today and plugged it directly into the back of the BT box and the aerial into that
It comes set at 100% and you can use the little red dial to turn down the signal strength. You can literally put the SS and SQ on-screen and watch it riser and fall with turns of the dial
Ive got it set with 90% SS (down from 100%) and the SQ is sat at 100% consistently (from fluctuating between 50-100%)
The picture is perfect on every channel and hasn't skipped a beat. Worth every penny of 6 quid!
Message 14 of 14
@Mark_lacey
I was pretty sure that would be the solution. Certainly proves the opinion that the tuners on these Pro units are no better than previous versions.
