Message 1 of 2
BT TV PROBLEM
We have a problem when using subtitles it seems to corrupt our TV channels and recorded programs.
This causes programs to freeze and often reset to the start of the recording .
Also the subtitles freeze or lag behind  when using fast forward or pause controls.
1 REPLY 1
Message 2 of 2
Re: BT TV PROBLEM
This is a known problem and we are waiting for it to be fixed.
If you turn subtitles off before skipping through recordings, it should not happen.
Richard
