Message 1 of 5
BT TV Pixelating Channels
Some channels such as Quest & QVC are pixelated this started about a week ago and is still ongoing, both channels have a 100% signal quality & 92% signal strength. I live in the North East and wondered if any one else is having the same issue.
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: BT TV Pixelating Channels
Are these HD variants? If so they're due to be switched off so may be on reduced power.
Message 3 of 5
No these are the normal SD channels strangely all other SD channels are fine
Message 4 of 5
With such high strength and quality it could be that they're overloading the tuners in the box. You probably benefit from a signal attenuator which can be picked up for a couple of quid on Amazon. This will allow you to turn down the signal strength being received.
Message 5 of 5
Hi ok thanks for that will give it a try
