Message 11 of 16
Re: BT TV Pro Box, Amazon Video and Atmos Audio
Hello
Thanks for the Reply.
I am going to see if @DarrenDev can enter this Discussion as he knows about the Apps.
Kevin
Message 12 of 16
Ok but it's not an app issue.
Message 13 of 16
Hello
Thanks, however, I Contacted Amazon Prime Video Support and they confirmed that HDMI 2.1 is not required for the App.
I am just trying to cover all bases 🤓
Kevin
Message 14 of 16
It technically isn't but when you're pushing a lot of data through, you could be hitting a bandwidth limit on the HDMI 2.0 standard but if you want to ignore my suggestion which is based on first hand experience of practically the same issue, that's fine but I'm quite happily watching Good Omens 2 in UHD, in HDR10 with full Atmos uncompressed audio with zero issues so it's clearly not an issue with the Pro Box or Prime app... 👍
Message 15 of 16
Hello
Utilising an HDMI 2.1 Cable on equipment that has HDMI 2.0b will offer no benefits of HDMI 2.1 including the extra Bandwidth.
Kevin
Message 16 of 16
I cannot offer any advice other than what has been suggested but wanted to say my setup is similar - box connected to a marantz amp - and have no issues receiving Atmos.
