Message 1 of 3
BT TV Pro remote pairing
Hi All
I have just installed BT TV Pro which all works great apart from syncing the BT remote to my TV. I press Home and 9 and it works initially on the volume, but then doesn't, and I have to do home and 9 each time to sync the remote.
Any ideas
2 REPLIES 2
Message 2 of 3
Re: BT TV Pro remote pairing
Have you checked the Bluetooth Remote settings on the Pro Box?
Message 3 of 3
Yes, tried both settings and it won't work
