Message 1 of 13
BT TV and HDMI
Having switched from Sky, I thought I would just plug in and go using existing generic hdmi cables. The bt box flickers on then no picture and the says no signal (checked cables with sky box and all working) - any suggestions? (Cables are in wall so not easily replaced).
Have plugged in a new free from wall cable but no joy
12 REPLIES 12
Message 2 of 13
Re: BT TV and HDMI
@KennyA1 In theory, HDMI cables are generic, although different HDMI version support can be an issue, i.e. older cables can't support 4k/UHD, HDR etc. But if you've been running Sky Q with 4k working, then this should work.
Have you tried connecting to another TV to see if the issue is the TV box, the cable or the main TV?
Message 3 of 13
Re: BT TV and HDMI
Tried spare tv and all working so it’s something to do with tv not recognising the bt box?
Message 4 of 13
Re: BT TV and HDMI
A lot of modern TVs have more than one HDMI setting.  Mine has three, despite only having the one socket, and the BT box works on HDMI3...for some reason I've never looked into
I’d try flicking through the TV settings and see if a different one works.
Message 5 of 13
Re: BT TV and HDMI
@Agree with @WSH . Could be HDMI modes, something in TV settings or even a dodgy HDMI port on the TV. I'd bet on the first 2, though!
Message 6 of 13
Re: BT TV and HDMI
We thought that too but just doesn’t seem to recognise the bt box - does with sky in hdmi 1 & 2 which is weird
Message 7 of 13
Re: BT TV and HDMI
I’m not familiar with the latest BT box.  (Mine’s ancient).  Is there more than one output mode on the box?
Message 8 of 13
Re: BT TV and HDMI
@WSH  there's a few output modes on the Pro box and mini to set the resolution; 720p/1080i/1080p/UHD 50fps 8bit/UHD 50fps 10bit
There's also Frame rate matching, which is still not quite well, so recommend leaving that off.
Message 9 of 13
Re: BT TV and HDMI
Box works using cables on other TV - think it’s definitely tv related but can’t work out the solution
Message 10 of 13
Re: BT TV and HDMI
Annoyingly the tv recognises the box for a split second then it shows as no connection
