Message 1 of 4
BT TV without aerial
Hi I'm just setting up my Pro TV box and the aerial I have doesn't fit. Can someone please confirm which channels I WON'T get by not using a aerial. Thanks
3 REPLIES 3
Message 2 of 4
Re: BT TV without aerial
Hi @Sammiesam
In IP mode you'll currently get these freeview channels.
Message 3 of 4
Thanks @Andy005  but I'm after which channels I won't get, to see if it's worth getting an aerial or not. Do you know? Or know where I can find this info please? Many thanks
Message 4 of 4
As a guide see the Freeview listings here and compare the two lists.
