Message 1 of 3
BT Tv box connection to full fibre hub 2
Hi, looking at getting the bt tv box and was wondering if I can to connect my smart hub 2 wirelessly plus, do I need a physical Ariel anymore? Trying to cut down in cables to hide.
tia
2 REPLIES 2
Message 2 of 3
Re: BT Tv box connection to full fibre hub 2
You don't need an ariael with the BT TV Pro as you can get all the channels over the internet including some Freeview ones and it connects wirelessly to the supplied router.
Current IP Freeview channels can be found here https://www.bt.com/help/tv/guide/ip-freeview-guide
Message 3 of 3
