Message 1 of 2
BT YouView DTR-T4000 stuck in maintenance mode, none of the menu options resolve it
My NT YouView DTR-T4000 box is stuck in Maintenance Mode.
None of the menu options seem to work, I've tried Software Reset, Factory Reset (keep recordings), Factory Reset (delete recordings). The Internet / USB Recovery options don't work either, although they don't seem to do anything other than timeout.
Whatever I do, it comes back to the maintenance mode screen again.
The box is old, long since out of warranty.
I'm wondering if the hard drive has failed, perhaps I could replace it and get it working again?
Does anyone have any experience with this kind of fault, or any suggestions about how to revive it?
Thanks!
1 REPLY 1
Message 2 of 2
Re: BT YouView DTR-T4000 stuck in maintenance mode, none of the menu options resolve it
Thanks!
Yes to all
YouView T4000 4k UHD Hard Drive Repair Replacement Guide Tutorial By TheCod3r - YouTube
