Message 1 of 3
BT YouView Digi box, no sound on switching on
Hi, I have a BT You View Box Humax DTRT 2100   and when switching on and selecting a channel there is no sound. I know its not the TV as I can watch a Samsung TV channel and the sound is OK. I have checked the volume is at a reasonably high level on both the TV and Humax remotes.
To clear the problem, I have to switch the power off the YouView Box and reboot, the sound comes on immediately after the restart.
Can anyone please help how the problem can be overcome?
2 REPLIES 2
Message 2 of 3
Re: BT YouView Digi box, no sound on switching on
Check to make sure AD button to make sure that Audio Description hasn't been turned on by accident
Message 3 of 3
Hi Nigel, apologies for the delay in responding, unfortunately the problem hasn't re-occurred but if it does, I will check to see if the AD button has been pressed in error. Thanks for the advice
