Message 1 of 2
BT Youview box upgrade
Hi
I have a BT YouView box (the one still supported). After a while, I know mthey suffer from the same problem as any computer, ie the hard drive gives up. It easy to change one & I have done it before, but my question is can I put an SSD instead of a mechanical hard drive as this would be likley to last longer, and can I use a 1TB drive for more capacity?
Nigel
1 REPLY 1
Message 2 of 2
Re: BT Youview box upgrade
If you can swap out the HDD and it works there is no reason why you cant put an SSD in that has the same interface, IE SATA I assume?
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
