Message 1 of 6
BT change to EE Screen colour has changed
Since the change from BT to EE my tv screen has changed colour to a yucky yellow. I cant find any menus to change it back. Can anyone help please?
5 REPLIES 5
Message 2 of 6
Re: BT change to EE Screen colour has changed
Have you checked your connections? Sounds like a plug may need reseating as a loose connection can make things yellow.
Richard
Message 3 of 6
will do. thank you so much for your quick reply
Anonymous
Not applicable
Message 4 of 6
Assuming you mean the colours of the menus, they are now EE green/yellow rather than BT purple. There is no option to change.
Message 5 of 6
I like the new colours. Highlights very clear and everything clearly readable.
Message 6 of 6
If you don't like the new colour scheme, you can always turn on "High Contrast Colours" which you will find in Settings/Accessibility & Language/Appearance. This turns off the colours and makes everything monochrome.
Richard
