Message 1 of 11
BT pro box order delay?
Hi guys,
has anyone else ordered a pro box for tv and actually received it?
I ordered mine on jan 2nd and it’s still not dispatched! Not impressed, especially when my youview box keeps losing WiFi connection over the past few days
thanks
william
10 REPLIES 10
Message 2 of 11
Re: BT pro box order delay?
Sorry to hear of your issues - I can see that it's still waiting for the box to be picked at the warehouse. Given that this should have happened within 24 hours, your order definitely hasn't reached them - it'll need to be resubmitted. Your best option is to call or use the online chat facility.
Message 3 of 11
thanks for the reply, guess I thought this would have been flagged automatically since they are waiting on me returning my youview box, no problems, will call them this afternoon 👍
Message 4 of 11
I have been waiting on my BT Box pro for a number of weeks and still not received it.  Despite raising a complaint and making several phone calls, I keep getting told that my hardware will be dispatched ‘soon’.  My patience is wearing very thin.  Any advice other than cancelling my subscription?
Message 5 of 11
@Potholedodger  Just cancel your subscription. The fact you’ve already complained and you’ve still not received the box or been updated about why it hasn’t been sent out indicates this isn’t a priority for them. At the end of the day, you are the customer, you don’t have to give them your custom. I’m sure there are better alternatives available.
Message 6 of 11
@Potholedodger I can confirm that NO order has been placed for a TV Box Pro. I can see a request for a TV Box Edge replacement, which you already have.
A colleague will raise the order for you shortly, and it should be with you Saturday/Monday.
Sorry for the inconvenience - I'm unable to explain why your previous efforts haven't been successful.
Message 7 of 11
Well if anything, my ahem 'advice' was enough to get the reaction I intended for @Potholedodger  I learned long ago, poke hard enough on this forum for a result.
Message 8 of 11
Thank you Darren.  I hope this is the case as all previous contacts with BT have stated that a box would be on the way.  Fingers crossed that matters are now resolved.
Message 9 of 11
Thank you Kimberlin.
Message 10 of 11
Your 'advice' had no influence on my response @Kimberlin
Where I can help, I do.
