Message 1 of 8
BT remote not working with hitachi TV
I’m trying to connect my BT TV remote to my hitachi tv, I’ve used 2424 and 2811 code, still not working. Are there anymore codes or anything? Please help? Thanks
7 REPLIES 7
Message 2 of 8
Re: BT remote not working with hitachi TV
The model number for the tv is 58HK6100U
Anonymous
Not applicable
Message 3 of 8
The code for Vestle is 2811. They manufacture several tvs with identical internals Hitachi being one of them.
If this codes not working then try resetting your remote.
Message 4 of 8
It doesn’t work…
Message 5 of 8
Hi @Reece1673
Have you tried resetting your TV remote?
Chris
Message 6 of 8
Yeah, doesn’t work with those codes still.
Message 7 of 8
Thanks for trying that, @Reece1673
If you've followed all of those steps and it still isn't connecting, you may need to use your BT/EE TV and TV remotes separately.
Chris
Anonymous
Not applicable
Message 8 of 8
Or....buy a new youview remote or if in contract contact BT and they'll sort it.
