Message 1 of 4
BT tv pro box rewind
Hi is there a quick way to get back to live TV when you rewind other than fast forward on the BT TV pro box thanks my last YouView box you pressed a square button on remote to get back to live
3 REPLIES 3
Message 2 of 4
Re: BT tv pro box rewind
Hi @Peter6789
You have possibly two options - Firstly, using the F1 Pro Box remote press up channel then down channel should return you to live.
Second option is.  if you still have an older Z4, G4 or G5 STB remote - As long as you are 'line of site' with the F1 Pro Box, you should find that the square button still works.
Message 3 of 4
Thanks I never thought about using old remote 🤗it’s actually a better remote than the new one which is now back in the box 🤔thanks for the help
Message 4 of 4
option using the square button on old remote no longer works to get you to live TV after recent update to EE branding 🤕
