Message 1 of 2
BTTV pro box stuck on lets get started page
Hi, I had read that the pro box you can stream terrestrial channels and to do a factory reset with aerial unplugged to be given this option, I have now been left with the let's get started page, start set up and can't press the start set up button. Any ideas?
1 REPLY 1
Message 2 of 2
Re: BTTV pro box stuck on lets get started page
I think it loses the remote Bluetooth pairing so you need to reset the remote
https://www.bt.com/help/tv/fix-a-problem/remote/which-remote-do-you-have/resetting-your-remote-contr...
