Message 1 of 8
Box pro.Aerial connection
I have a boxpro.I retuned my aerial  tv channels & they all disappeared  & i get zero response from the aerial connection on  the  boxpro,retuned a few times & nothing,just get zero.I've fitted a new co-ax  plug didn't make any difference.I don't think that it's my aerial because i have a seperate aerial connection to my TV & that works ok,so i think it is probably the aerial in on the box pro,anyone any ideas.
7 REPLIES 7
Anonymous
Not applicable
Message 2 of 8
Re: Box pro.Aerial connection
From my memory the BT box on start up asks you to choose between aerial and wifi for the channels list.
It might be set up for the latter
Message 3 of 8
Hi @Cliff  why did you opt to retune  , were you having issues before the retune attempt   if so what were they?
You mention the TV having a separate aerial connection , how is the aerial feed split ?
(@Anonymous were the Box Pro to have inadvertantly to have  set up in IP mode then the Retune option would not I believe be available in the Settings so the fact thay Cliff is able to attempt a Retune indicates the box is currently in Aerial mode albeit with no channels.)
Message 4 of 8
Yes ,i was having problems.I would get flickering & actual loss of picture,this is why i opted to retune.
The aerial feed set up is.Cable from the wall socket to a splitter,cable from pro box to the splitter & cable from the tv to the splitter.I don't get any problems from the TV ,tuner.It is probably 3 months back when i started getting issues with the probox connection,then it just stopped completely.
The splitter is a small box ,about 4" x 2" x 2".
Message 5 of 8
Hello Cliff,
       I believe that,if working correctly,you don't need to use the Splitter.Can you try plugging the Aerial Cable directly into the  Pro Box "Aerial In" then,if you have an HDMI Cable connect that  from "Aerial Out" to TV.In Picture and Sound of Pro Box select "Antenna Out" .Scan for Channels with Pro Box a if now OK TV should also display same Channels.
      Just an idea.
Message 6 of 8
Try using the cable the TV is connected to for the pro box, and vice versa. If the pro box is now fine and the TV is having issues it's probably a fault with the splitter.
Message 7 of 8
Sorry for taking so long to reply.Connecting the tv cable to the probox didn't make any difference,connecting the probox cable to the tv worked ok on the tv,i think that probably points to an issue with the aerial in on the probox,i'll get onto BT & see what they say.Thanks  for your posts.
Message 8 of 8
@Cliff ,
It's possible that the signal from your aerial is weak. A two-way splitter in the aerial feed halves the signal strength even if one of the splitter output sockets isn't used. For some unknown reason, TVs seem to be able to cope better with a weak signal than TV receiver boxes.
As @graybag suggested, have you tried removing the splitter and connecting the box pro directly to the aerial wall socket? If that works, you could use the aerial out socket of the box to connect your TV.
