Message 1 of 7
Bt TV box
Hello, I'm thinking of getting BT tv but would like to know how to access Nowtv and Netflix, is it via the normal app or are there as extra channel listing's.
Tia.
Del.
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: Bt TV box
 There is no BT tv it's EE tv.
 But I'd seriously have a rethink if I was you.
Buying Now through a third party excludes you from the ever present now offers.
You'll literally save hundreds by buying now directly.
To answer your question you can still use the now/ netflix app on EE tv  just sign in with your current login details
Message 3 of 7
Re: Bt TV box
Thanks Kodikid, that's a good point about the offers.
Cheers.
Message 4 of 7
Re: Bt TV box
Just remember if you decide to go down the Now direct route, there is no option to record anything. It depends what is important to you.
Message 5 of 7
Re: Bt TV box
Thanks hunter, do you mean NowTv is recordable on the BT box ?
Message 6 of 7
Re: Bt TV box
Yes, all channels are on EETV's EPG and are recordable. But if you go with Now direct they can't be used, you can only use the app. So it really depends on your needs. If you watch a lot of sport and you wish to timeshift anything to watch later you may prefer EETV. If it's only entertainment and movies you want, then subscribe to Now as most stuff is available on demand.
Message 7 of 7
Re: Bt TV box
Thanks Hunter.
