Message 1 of 3
Bt tv box pro Internet problem
I have had the Bt tv Pro box for a few months connected by ethernet cable.
Everything worked until recentl,now the Internet connection is lost.
I have tried swopping cables ,tried setting up WiFi via the Bt wholehome system without any success.
I have also tried resetting the box but the Internet still doesn't work.
All my other devices work OK.
I would be grateful for any advice.
2 REPLIES 2
Message 2 of 3
Re: Bt tv box pro Internet problem
I have also had trouble with Ethernet, but over WIFI is fine.
As for your issue have you tried factory resetting the box?
Message 3 of 3
Thanks for the reply,yes I've  tried the factory reset.
I'm  going to try setting the WiFi connection again.
Fingers crossed.
