Message 1 of 3
Bt tv box pro
Just a quick question do you need to be on bt broadband to receive the internet tv channels when setting up a bit tv pro box?
Cheers
2 REPLIES 2
Message 2 of 3
Re: Bt tv box pro
If you’ve got a BT Pro tv box and you want it to operate in IP mode then you need a BTTV subscription which is also dependent upon having BT Broadband, I’m afraid.
You are able to use a BT Pro TV box to watch and record the Freeeview channels in aerial mode and also to use the apps available on the box with any broadband provider.
Message 3 of 3
Re: Bt tv box pro
Thank you for the info 👍
