Message 11 of 14
Re: Bt tv extra box
Yes, but has anyone actually taken this option up? Is it recorded on your account that you are using your own box for extra subscription. I think my concern would be that if I were to cancel my extra box subscription, I’d then be chased up by BT to return a box that I’d never actually received.
Message 12 of 14
Re: Bt tv extra box
You'd be fine, your account would show the 2nd box subscription but not the Youview box in use, so you wouldn't be asked to return something BT never provided, you also wouldn't have any warranty from BT as it wasn't provided by them.
Message 13 of 14
Re: Bt tv extra box
Just to add to the above , I did exactly this a couple of years and no problems at all.
Message 14 of 14
Re: Bt tv extra box
If you do the above do you still have to have a 12 month contract on the extra box part?
