Message 1 of 6
Bt tv pro box
I have a bt tv box pro and it’s connected using my broadband, no aerial as it was advertised on the fact that no aerial needed.. Why can I not record a channel and watch the said channel at the same time ? And why can I not start play the recording as it’s still recording ?
very disappointed with the above as this is the most logical thing that other boxes manage to do…. literally you get a blank screen if you try to watch the same channel you are recording and it will not play the recording until it finishes 😞
Tags (1)
5 REPLIES 5
Message 2 of 6
Re: Bt tv pro box
Hi @Kikiwoowoo ,
Not sure why you are experiencing this.
i believe that both those actions should be possible.
There is a limit of 2 multicast streams but as the recording and viewing is of the same stream that should be possible. (and only count as 1 of your streams).
With regard to watching a recording from the start whilst it is still recording , if when you open the recording it doesn’t start to play from the beginning press 0  (zero) on your remote and it should position the recording at the beginning .
Probably worth restarting ( rebooting)  the box to see if that clears the issues as what is occurring isn’t normal.
Message 3 of 6
Re: Bt tv pro box
Hi @Kikiwoowoo
I have just replicated what you've been trying to do and it worked perfectly for me. I recorded two channels at the same time and on both I was able to watch and record at the same time, and play each recording as it was recording.
Try what has been suggested as it's not a limitation of the box.
Message 4 of 6
Re: Bt tv pro box
Yup, I'm with the others on this. Sounds like a box issue because I have a Pro Box running in Internet mode and it works perfectly. If you try the other recommendations and they don't work, the final thing to try is a factory reset and run set-up again because something may not have gone right during the initial set-up
Message 5 of 6
Re: Bt tv pro box
Thanks everyone for your replies I’ll give all suggestions a go..
I’m pleased to know that it should be possible to do both actions as I thought it might be because I don’t use an aerial..
thanks again and I’ll let you know how I get on
Message 6 of 6
Re: Bt tv pro box
Thanks again all, I’ve done a factory reset and have re-tried my actions last night and all working fine now …..
Appreciate your suggestions and help 🙂
