Message 1 of 2
Bt tv pro with orbi
Hi is there a way to use my orbi setup to get all channels on my pro tv box. I'm not using the Bt smarthub 2. Thanks for any help.
1 REPLY 1
Message 2 of 2
Re: Bt tv pro with orbi
Not quite the same setup, as I have FTTC but i have scavenged the net to try and get the IPTV to work over the last few days and then came across this: https://www.draytek.co.uk/support/guides/kb-vigor-130-bridge via https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Using-Orbi-RBK852-with-DrayTek-Vigo...
and it actually works. I'm not sure if any of it is applicable but it shows you that the Orbi can do it but the modem needs to be in full bridge mode.
